EvilBeast
The fuel pump relay is in a "Power Distribution Box" and is totally controlled by the ECM. I dont have access to the control line unless I splice into it. However, the "Fuel Pump Feed" which is the output of the relay when it's energized, only has power for 3secs after KeyOn, not when cranking, thus my question above: Does the ECM have to see some RPM (i.e. crank rotation) during cranking before it will supply fuel pump power?
