Herr_Poopschitz
I’d been out of the Mopar circle since the late 90’s, when I got into late model Mustangs, Camaros, and Vettes. In putting together a combo for my own car, I’m trying to apply much of what I learned to my 440, and glad the aftermarket has stepped up over the last 15 years. I’m presenting this solely as a topic for discussion…no attacks on any one person’s combo. I’m hoping we’ll have an educated conversation of the way an engine works and how certain cylinder heads can help or hinder in achieving certain owner’s goals, and possibly addressing different, and potentially cheaper, paths of getting there.
First, for comparison, I'm helping a friend put together a combo for his 71 Chevelle...I convinced him to go w/ a naturally aspirated LS3 based combination, specifically.
During my research, I’d found the LS3 heads use an intake port that measures 2.55 x 1.25 (3.19 sq in), w/ a 2.165 valve...also w/ an offset rocker, so ‘no’ pushrod pinch reducing the port cross section. This is on 376 ci.
That seemed like quite the intake port, so I looked up a BBM for comparison’s sake. A Fel-Pro 1218 Max Wedge gasket measures 2.622 x 1.3265, and because of the valvetrain geometry the port will have a slightly smaller cross section due to the pinch. Using the industry standard BBM Al head, the RPM has a 2.14 intake valve.
Let's say it's a wash as far as port size goes, to keep things easy. So…the newest tech engines using pushrods are using heads similarly sized to that which most Mopar guys are afraid to use on an engine that's 65 ci larger. This begs the question of why we’re seeing so many put a head smaller (std BBM) than this on 500+ ci engines (more than 125 ci larger).
Why can they get away w/ such a big head and we can’t, even though we are using much larger, and in many cases ‘warmed over’ or ‘performance’, engines?
Please educate me.
Please educate me.
