m880cummins
So, motivation strikes like waves and in the last few weeks of my time as a student at Penn College for Restoration I wanted to take full advantage of the facilities we had. Dad has had a 65 Coronet completely taken apart since I was 3 years old. Last sunday we had a guy come dustless blast the shell and monday it was in PPG DP epoxy primer. Over the course of the week the unibody was measured old school (tram gauges and self centering gauges) and measured with a laser measuring system to confirm the body is in good condition and straight.
I acquired a footwell section from a fellow member (Thanks Ed!) in New Jersey and Dad went to see Kramer and bought an AMD floor pan and aluminum door hinges. Our subframe connectors go through the floor and are made of 2x3 box steel .120 wall. The firewall was drilled off and a better section will be installed. Also deleted all cowl related items and hand fabricated new pieces to match the left side.
Taking it home this coming week and doing inboard SS leaf springs, getting the suspension under so it rolls and moving onto other metal work and installing fiberglass to check fitment. Then it will be installing the 400 block and hemi 4 speed box for test fitment.
DAD!
DAD!
