So my Dana 60 has started leaking fluid, and I think its coming from the front yoke area. Haven't crawled under there yet to find out exactly where, but will do so tomorrow. The leak started roughly two weeks ago, and its a gusher. One day I wiped up the puddle and the next day it was back. From a previous check, the fluid level was right at the filler hole and its given me no troubles.
Talked to a buddy of mine, and some initial diagnositc work he wants me to do is grab the yoke and see how much play is in it. He's wondering if the lock nut has loosened itself.
I read the FSM and it says to check the vent tube and make sure its clean or else the internal pressure will force fluid out the seals. Where is this vent tube? Is it on the diff housing or an axle tube? I was under the car a few weeks back messing with the pinion snubber and I don't remember seeing this vent tube, or at least it didn't readily jump out at me. Is it easy to miss? Is it just the vent tube or might there be a hose connected to it and venting elsewhere? How common would it be for this vent tube to get clogged up?
Anything else I should look for while troubleshooting the cause of the leak?
Lee
Lee
