Dana 60 parking brake cable routing
hunt2elk
1:07 AM
WI
8 3/4 rear ends have this welded clamp on the right side of the axle to secure the e- brake cable. Was under my Bee that has a Strange 60 and noticed that that clamp is missing and the cable has wore some paint off the frame from not being secured in this area. Did original Dana's have this clamp as well?
I need to make one of these brackets that the cable clamp bolts onto for my S60 in my '69 Charger. Can anyone get me some close up pictures with dimensions?
Thanks, I'll check tomorrow to see if there is a hole in that area on mine. Seems odd Strange wouldn't make some provision for securing the cable.
I know this is an old thread, when ordering your S60 from Strange you have to ask for the clips. A little Strange if you ask me, pun intended.
Hydraulic brake line clips came welded to the housing. What I need is dimensions/ pictures of the bracket that the parking brake cable clamp gets bolted to.
Anyone help you out yet? I can wrestle out a 68 Dana 60 housing I have and provide pics/ measurements
No help yet.
I need to fabricate this bracket -preferably today- but I'm kind of flying blind here.
I definitely would appreciate your help.
Ok...let me get it out n on the bench ..I'll be back shortly
Be sure to post some pics of your finished product!
I cut it out of a piece of 1.250 X 1.250 X .125 wall tubing I had laying around.
I think I came pretty close to the real thing.
Here it is bolted to a piece of aluminum bar stock so that I could clamp it in place for welding.
Thanks again to Dutchrebuild for the pictures and measurements.
Don’t know. Ill submit this anyway. Good luck.
