GearAddict
Below copied from my build thread... any help appreciated.
Project today consisted of changing rear gear oil out and inspecting carrier and axels to see what I've got under the cover in the Dana....
Thank god I did this now!!! In the pics below you can see 1 of the 3 ring gear bolts that is 90% unthreaded... I shudder to think what would happen it it worked its way out any further. If I re-torque em to spec without removing the carrier am I ok? I'm going to take it in to do a gear swap soon, but was going to drive it a little between now and then. Should I put any loctite (or similar product) on the threads?
The good news is I had thought I was going to have to change carriers since I have 4.56 gears, I was assuming it was a 5 series carrier, but it looks like someone used a gear shim on a 3 series and since I'm hoping to go with 3.54 gears I should be good. (Please someone more knowledgable tell me I'm interpreting that right?)
Also, I don't know 1 carrier type from another.. Anyone recognize that carrier? Powr-Lok maybe? I'm headed back out to the car shortly to tighten up the ring gear bolts. when I do, I will have to spin the rear wheels and maybe I can get some numbers off the carrier.
View attachment 255694View attachment 255695View attachment 255696View attachment 255697
