INTMD8
Hello,
I'm in the process of swapping a 3.54 for a 4.10 in my Dana. Used original gear.
The 3.54 was toe biased on the drive side and only .006 backlash when I took it out.
It was however completely quiet.
I first installed the 4.10 with the same shims and it was even more toe biased on the drive side and backlash opened up to .010.
I thought to get the drive side more centered I needed to remove pinion shim so I went from .0465 to .030. (removed .0165).
This opened up the backlash to .016 and I ran a pattern like that as I don't have a press at home to remove the carrier bearings.
This put the pattern at the extreme edge of the ring gear.
Any suggestions on where to go from here? Thinking I removed too much pinion shim as I don't think tightening up the backlash is going to fix the second pattern set pictured.
Thanks!
-Less pinion shim, .016 backlash-
Thanks!
