Magnes
- 1:04 AM
- Nov 14, 2013
- in the Houston Texas area
1972 Plymouth Satellite Sebring plus. Rallye dash.
I bought this car that had been sitting in a warehouse for many years. I have been working out a bunch of the bugs but I'm having trouble with a couple things and wondered if any of you guys could bounce some ideas off me.
The gauge lights in the instrument panel aren't working. When I got the car they worked and would dim as they were supposed to do. While troubleshooting a headlight problem, the headlight switch/gauge dimmer broke on me and none of the instrument gauge lights would work anymore. I replaced the headlight switch/gauge dimmer today and have the headlights working now but those instrument gauge lights will not come back on. I spun it back and forth but nothin.
The other problem I am having is my brake lights won't work. There was a jumper wire that someone has installed at some point previous to me buying the car. The jumper wire went from the brake sensor at the pedal and ran all the way back into the trunk and hooked up to the wiring there. At some point during the body work I removed that jumper wire and now my brake lights will not work. I'd rather have the brake lights working as intended as opposed to "rigging" them to work but I'm having trouble figuring this out.
Any ideas what might be the problem or solution?
I'm just going to throw a bunch of info out there and see if it gives you guys any ideas...
All my fuses are new.
New flashers.
New headlight switch.
New bulbs everywhere except in the dash.
New high/low beam switch.
Headlights work. High and Low.
Parking lights work.
Blinkers work.
Emergency flashers work.
Tail lights work.
Side markers all work.
License plate light works.
Dome light works.
Glovebox light works.
The only things not working for me are:
Instrument panel lights
Brake lights
New flashers.
Blinkers work.
Tail lights work.
Dome light works.
Brake lights
