Deleting ballast?
///Matt
9:22 PM
Texas
Hey all,
440, has a MP electronic distributor, HiRev7500 ecu, and MSD blaster 2 coil.
Am I good to bypass the ballast resistor? If not, what needs changing before I can, and to what?
I think I would just leave the Ballast in place. They're cheap enough to keep an extra or two in the glove box, looks factory, you don't have to do any re-wiring and it's not hurting anything.
I think with a multi spark ignition such as MSD, you definitely can remove the Ballast and you'll be doing a bunch of wiring anyway with that system. But with your system which is similar to mine (I have the orange box with a Blaster II), I'd keep the Ballast in place. BTW, I don't think think the Blaster II made any difference at all over my stock coil, at least with mine. It's pretty and red though!
Hey all,
Bypass it
You can also solder a wire across the back of the resistor to the pins if you want to keep it looking stock.
I did it but changed the coil from 1.5 ohms to a 3.0 ohm coil. Mopar electronic with orange box. Been about 5 years now with no problems.
