b569rr
just fired up the 493 cross ram and it runs great except that the alternator won't charge. I have a Denso unit from 440 source that I bought in 2007.
I have the single field wire hooked up correctly and it senses battery voltage 12.6.
The blue sensing wire is hooked up to my in tank fuel pump and reads 0.5 volt drop at 12.1 which is normal.
My battery red terminal is hooked up to a new #4 wire that goes directly to my battery via a resetable circuit breaker that is good to go.
The green idiot light wire is capped and I did not hook it up?
Strange it's dead with power in on the hot and sensing leads. Does the idiot light wire need to be connected?
I'm headed to napa right now to get it tested. Was hoping to go set the rings immediately. I hate shutting it down.
