FYI, un-milled 906 heads are about 88 CC. If the block has been milled straight, get the correct piston for the CR you want. As Gary said 2.067 gets you in the ballpark with about .010 down in the hole. That's where I ran most of my 440's. The 915 head gets you about .75 + CR increase. Both 906 & 915 really like pocket porting. The area under the valve seat is very poor in stock shape. The new valve job machine equipment can correct for this. A little work with the grinder makes big power improvements. I have done several dozen sets of 906 & 915 heads, not so much variability in them. I grind out the differences in the ports. Mill the deck to your specs. If you measure everything, you know what you got. Later head castings have bigger CC chambers.
