Thanks for all the help. I suspect it is the alt, I just want to try a few tests to confirm it.
I am just getting to this electrical problem after a nasty winter. I have performed the alt test and there is a voltage drop in the meter. My question is, how do I know for sure it is the alt and not the regulator?
I got this info below from this site I believe:
If this is low, no charge, pull the field wire off at the alternator(HOW DO I KNOW WHICH ONE THIS IS?), and install a clip lead from the output stud on the alternator (HOW DO I KNOW WHICH THIS IS) to the field terminal on the alternator. You should hear the alternator "grunt" and with the engine GENTLY brought up a little in RPM, the battery voltage should start to climb. Be careful not to ref the RPM too much, and monitor battery voltage. Do not rev enough to bring voltage over 15, 15.5.
If you get no output, check the voltage at the alternator stud (WHICH STUD?). Should be close to battery. If you have battery voltage (HOW MUCH?)at the stud, but no charging voltage increase, you have something wrong in the alternator
If the voltage at the output stud is low, much lower than battery, you have a wiring problem in the charging/ output circuit, either the ammeter or the bulkhead connector is your no 1 suspects
If this test DOES show a marked voltage increase, you have either a wiring problem in the regulator/ field circuit or a bad regulator.
To check for that, unhook the wires from the regulator, and connect them with a clip lead (BOTH LOOPED OR CONNECTED TOGETHER?), reconnect the field wire at the alternator (WHICH ONE IS FIELD?). As above, the alternator should output "full tilt," and be careful of the RPM
If this test shows a charging increase, you need a regulator.
Quote Originally Posted by Pops1967GTX View Post
SORRY GUYS I AM NOT GOOD AT THIS. I KNOW I SHOULD JUST BUY A REGULATOR AND PUT IT IN, BUT I AM TRYING TO LEARN A BIT TOO. tHANKS
