Direct fit aluminum radiator
Dodge500
8:20 PM
SE PA
In case anyone is interested, the Wizard 62-65 Dodge direct fit aluminum radiators are not really direct fit, especially for a 63 Dodge Polara. I tried to install the first one sent to me and my hood hit the fill cap because the radiator sat too high. Not only did it sit too high using the stock location, the radiator itself is too high for the space allotted for the stock radiator. After complaining they sent me a new one that met my dimensions but it still needed modifications to fit.
The Champion aluminum radiators aren't "direct fit" either FYI
I checked the Griffin site and there is no direct fit radiator for a 63 Dodge. They only list Plymouths.
You would think the manufacturers would then list both. Wizard only lists Dodges and Griffin only lists Plymouths. All I know is I had a heck of a time installing my Wizard and it just doesn't look right sitting in my car.
yeah thats a Bummer ! look up the original radiator and cross it with other models to if the part number is the same
Thanks for the information but it's installed. As long as it keeps my temps down I won't complain.
break out the bucks and becool. they got all the guess work taken out of the equitation. drop it in hook up the relays,tempsenders, git ur wiring routed and clean .neever ever go above 195, plug and play with adjustability, sweet kit and yes expensive, how much gonna cost to do it twicE ???????????DO IT UR SELF AT WHAT MOTOR COMPRESSION,OCTANNE,CYLINDER PRESSURE,FED BUY THR JUICE/?
