Does it matter how the calipers are mounted on the spindles, front or back?
I have my spindles mounted to my K with the motor mounted already. The whole K is out of the car waiting on my torque converter to come so I can mount the tranny with it, along with a bigger than stock anti-sway bar with mine.
Can't remeber if I have them to have the calipers to be mounted in the front or rear, I think rear. My car is at my friends house so I can't see it to verify. Thinking I mounted them on the rear, didn't know there might be a mod to the line.
It certainly can be model specific, but even the more elusive 70-72 B/E body can be converted to disc brakes with original 73 up A body spindle, or 73 up B body tall spindle and the adapters. Proper spindles are out there. At that point you can buy 11" rotors with A17 bearing and KH pin calipers at your basic parts starts at a reasonable price. I am not sure these cars really need the heavier 11 3/4" rotor mod everyone pushes.
My 70 B body was upgrade years ago using original Mopar B body spindles and adapters. Along with calipers, rotors and Bendix booster and master cylinder. I recently replaced the calipers with rebuilt KH that were $20ea. The rotor is available as a one piece for about $60. This is the original small bearing style. You can get new disc Master Cylinder for about $40.
The hardest part is now getting the remanufactured Bendix booster. The core charge on one is now about $500.
I do believe that some retailers have been buying these parts up to resell until the core charges got out of sight.
At least one manufacturer has produced a new booster that is a close fit but pricey. G
Tor-red's ride is a '71 which is why he can still mount the calipers up front.Don't quote me on this as I have not yet installed the front disc hardware on my 68 Charger but from what I have read and been told, the pre 70 B body sway bar mountings are what create the need to relocate the calipers to the rear. The sway bar hangers are located at the front of the K member on the earlier B bodies while the 70 & up B and E body cars have the bar going through the K member. apparently, the longer sway bar must be in the way of the caliper on lock to lock turns. Someone told me that if you desire the front mounted calipers on the older B body cars you need a 70 or newer K member.
Many people agree with your recommendation. I just want to be certain that Dr Diff sent me the correct shields before I move on. I've got plenty of other stuff to do while I wait on his reply.Use your dremel, install bolts, move on. Those shields don't do anything but help hold heat in, that's why I don't use them.
