68gtx
i need some wheel bearing dust caps , where are you guys gettin yours.  i found doorman 13996 on ebay but really pricey, can find anyone that has them in canada
			i did an a-body swap on my 65 coronet. didn't help stopping much. i have a 69 coronet with power 11' drums that works better.
Swapping the spindles left to right, won't that put the ball joints in a bind?
My 68 coronet r/t had the front brakes swapped out before I bought it, I cannot get enough vaccumn to help my brake booster, unless I put car in netural and keep revs up when coming to stop sign, ok on highway. I would not let my wife drive it like this. One fellow told me if I changed to a 4 speed I would not have this problem, I don't know?
I'm needing a M/C and Brake booster for my Belvedere. Will the 98 Grand Cherokee some what bolt in.? The cam I'm running is pretty healthy. Am I going to run out of vacuum while braking.?
Its not bolt in, you have to modify the firewall plate, drill more holes and modify the pedal to accept the new location for the rod. So its not like a kit or anything like that. I can't answer whether or not you will run out of vacuum.
I went with SSBC because of the 4 piston calipers.The kit was very complete and I also stayed with manual non power.
I did the original drum spindle with SSBC Disc brake conversion, on my last 68 RR, that had manual 11"x3" drums, 4 piston "Force 10" I believe they were, complete kit, worked great... my current 68 RR will have the same brakes too, when I finally get around to it...
Dr.Diff also sells some decent kits from what I've heard, a little more money for either SSBC or Dr.Diff kits, but complete & all new parts, no searching wrecking yards or fitment issues either...
