Canadian1968
The car is 68 charger r/t with the original bendix front disc rear drum setup. EVER since I got the car back on the road the braking has been inconsistent. Lower speed its fine but at higher speed I get "shake " I guess I would call it. Sometimes worse than others. I'm pretty sure it's not the fronts as in don't really feel it threw the steering wheel .
I took the back drums off and just had a look around. I noticed that the brake shoe is not contacting on the entire shoes especially the one to the rear of the vehicle. It did look like some chatter marks on shoes as well.
I have another set of brand new shoes in the basement. I noticed holding them up that the pad on the new set sits differently on the shoe itself. In the picture you can see the pad of the front shoe sits up rather high almost the same as the rear. The new set I have the pad sits much lower, which brings the pad down lower in the circle.
Wondering if this would cause any problems ? Maybe I should have the drums turned ? Thoughts ?
