This does not matter. If your drum is offset too much it may bind with the backing plate or pinch the shoes between the backing plate and drum.
There are only two things it can be. 1) Binding drum to backing plates, or 2) binding the shoes between the drum and backing plate: Take off the shoes, put the drum on, and tighten the lugs (no wheels). Does it spin? No = your drums are mis-matched to your backing plates and binding. Yes = Your brakes shoes are binding between your drum and backing plate.
The trick then is figuring out which parts are mis-matched. Googling pictures of 11" front drums, yours don't look right to me. They appear that they may be offset too far inward from the hub flange.
