I myself am very stumped (no pun intended) the only thing left is to check axle play up and down that may cause the drums to drag.That along with axle end play if it is still tapered bearings.If the adjuster and lock is still there set end play to .008
These are just thoughts going thru my head. I'm still thinking of things that have happened in the past.
Also check the parking brake cables that go to the drums. Had a car that the cables were part frozen and wouldn't release all the way. Removed them,lubed them and that cured it.
I got a car once and the spreader bar for the parking brake was for a 11'' drum and installed on 10'' drum.
Shoes would not retract completely. ????
