MsMoparMarilyn
- 10:38 PM
- Aug 11, 2016
- Edmonton Alberta Canada
I switched to allen head bolts and washers to solve the problem with the socket on the bolt not fitting..Same story here...MP covers leaked no matter which gasket installed. Over winter in dry storage, the passenger side cover front tang appears to have cracked, and it was not over-tightened. I am prepping the original steel covers for a return to service and yes, the bolts will be torqued to spec. 383 with factory exhaust manifolds and heads. Does anyone else have to use a thin-walled 7/16" socket on the centre outside valve cover bolt on the passenger side valve cover?
I skipped page 2 and 3, but don`t doubt what Leanna said a bit. But mine were bought used from a guy out of Wichitaw, and I have had no problems w/ them. Must be way older, when they used to make things right !Thanks Cuda' Chick!
Same here, but around 2015. In my case it was leaking after changing the cam and I just snugged it down a bit more. The leak did not stop so another snug and SNAP. It was the outside right rear corner. After buying a new set I used RTV on both sides of the gasket so I did not have to torque them very much. I too blamed myself. Perhaps I was wrong.way back many moons ago (... 2002-ish?) I snapped the dog ear off of the first pair of these that I bought.. I thought I just over-torqued it
I have a set of M/T that will never get used again as they dont even begin to match the head matting surface at the dog ears and they are old castings.I've found plenty of other cast aluminum covers that were cracked or broken too but was hard to tell if they had casting flaws to start with. It pays to inspect any cast aluminum product be it Mopar or MT. I'm betting they are made in China now a days too?
