Or a eye bolt for adjustment.A turn buckle would look neater.
I took your suggestion and bought one....These are in stock:
A-Team Performance 5 1-2" ADJUSTABLE TENSIONING ROD HEIM JOINT ALTERNATOR BRACKET SBC BBC 350 454
Alternately, you could get parts from here and fab what you need:
Pilot Supplies and Aircraft Parts | Aircraft Spruce
Or you could just get a set of these Mancini Racing MagMount Motor Mount SetI do it differently. Take a stock motor mount and drill a 1/4" hole all the way thru it. Then take a larger drill bit and chamfer the hole on the side that will interfere. Go to the hardware store and buy a flat head 1/4" screw long enough to go all the way through, and lock it in place with a nut. I use a self locking nut so it doesn't loosen with time. Probably 50 cents in materials other than the stock mount. I broke 2 motor mounts on my Superbird, before a friend showed me this trick. Once installed nothing shows.
If you go that route and mount one end to the motor mount tab, the holes in the tab are 7/16, not 3/8.
Thanks....If you go that route and mount one end to the motor mount tab, the holes in the tab are 7/16, not 3/8.
Probably want the bolt to fill the hole with no slop.
I have several cars that I have done the same thing with the driver side motor mounts. Still has a little movement as to not transfer noise and vibration throughout the cars like solid mounts do, but yet still holds the mounts together from tearing.I do it differently. Take a stock motor mount and drill a 1/4" hole all the way thru it. Then take a larger drill bit and chamfer the hole on the side that will interfere. Go to the hardware store and buy a flat head 1/4" screw long enough to go all the way through, and lock it in place with a nut. I use a self locking nut so it doesn't loosen with time. Probably 50 cents in materials other than the stock mount. I broke 2 motor mounts on my Superbird, before a friend showed me this trick. Once installed nothing shows.
I was kind of curious but afraid to ask... I get why to use a chain, you have some slack so the rubber mount can do it's thing until the motor moves too much, the guys using solid bars or joints why not just put in a solid mount? figured it was something i wasn't seeing...We just rplace the left side rubber bisket with a block of aluminum. Drilll an tap for studs. Paint it black.
Absolutely. I use a solid mount(Moroso that I had powder coated black) on the driver side only, and no problems.I was kind of curious but afraid to ask... I get why to use a chain, you have some slack so the rubber mount can do it's thing until the motor moves too much, the guys using solid bars or joints why not just put in a solid mount? figured it was something i wasn't seeing...
I have one of those shumacher torque rods on my 67 belvedere 383 big block, not a huge torque monster, overkill is good sometimes.I have a Schumacher one goes from the block in the same ear and to the bolts that mount the front sway barlinks on the top of the k member. on a A body. Some one took over thier designs and are making them again. Darn I cannot think of who
I did it like this ^ but I used 5/16 bolt, look how twisted mine is at launch , injector stacks make it obvious LOL, has not broken YETI do it differently. Take a stock motor mount and drill a 1/4" hole all the way thru it. Then take a larger drill bit and chamfer the hole on the side that will interfere. Go to the hardware store and buy a flat head 1/4" screw long enough to go all the way through, and lock it in place with a nut. I use a self locking nut so it doesn't loosen with time. Probably 50 cents in materials other than the stock mount. I broke 2 motor mounts on my Superbird, before a friend showed me this trick. Once installed nothing shows.
I like the turn buckle design. Made mine similar except I bolted a plate to the front of the block instead of the back of the water pump and used a sway bar link rod bushings on the bottom to provide a little cushion. It's a 512 stroker motor with tons of torque and a manual transmission that launches hard through a Strange Dana 60. It goes to the drag strip several times a year and haven't broken anything yet.It'll work just fine... next step...
Best place that I had on a hemi..I like the turn buckle design. Made mine similar except I bolted a plate to the front of the block instead of the back of the water pump and used a sway bar link rod bushings on the bottom to provide a little cushion. It's a 512 stroker motor with tons of torque and a manual transmission that launches hard through a Strange Dana 60. It goes to the drag strip several times a year and haven't broken anything yet.
