dome light not working
paul1969cars
12:30 PM
new york
Im putting 69 charger back together. Door switches are in. Dome light not coming on. Blub is good. Is there maybe a fuse for this? I did have car completly apart dont know if I missed something. Door switches are both on a yellow wire that goes into under dash harness
Check for power at dome light as this turned on with ground at door switch also the correct bulb as must ground through the base connection not the socket
Had lots of switches over the years that didn't want to do their job. Both left and right sides ain't working?
If your car has been repainted, run appropriate pipe tap through door switch hole to remove paint and restore ground.
Do your dome lights work with key ON? Make sure your dome light circuit is wired to constant 12v. power. Usually comes off cigar lighter stud.
The dome
Light gets plugged into a harness in driver side kick panel
Both door switches are on yellow wires that go into wiring harness as wel
Is there a fuse for some light I’m missed possibly
Door switch IS the ground....power is always at the bulb. Simple meter check...
Agreed
Simple check...... Remove dome bulb (single element, dual contact). There SHOULD be 2 contacts in the socket. 1 should be hot at all times. That is the pink wire, if I remember correctly. The other contact is ground (yellow). If the pink wire isn't hot, or the yellow isn't grounded (door open) then ....happy hunting.
