Donny
- 9:32 AM
- Aug 28, 2009
- North East San Antonio TX
Hey Bernie. I have never used Copper Slag, however it is sold and used down here, but I've never done it. 700 bucks for the material? Wow, sounds like you are getting hosed. Can't it be recycled? The big thing you have to consider -- and it looks like you have, is securing the services of a local Media Blaster; which is seems like you don't have one there near you. So, you have to do it yourself. You didn't indicate what size compressor you have, but, anything that is 'perfect' for the job would be way too expensive to buy for one time use, so, likely you will have to use a more standard compressor. The key (forget air pressure for a bit) is air volume, which is measured in CFMs. Get the biggest compressor -- and you may want to rent one, and, perhaps a local equipment renter has a blast pot also to rent. Also, Soda Blasting is more mobile and perhaps there is one of these guys up there to assist you? However, the soda won't punch out/down the rust and or Bondo too well; you'll have to grind/sand it later. One thing you also may want to consider as a blasting media is Walnut Shells, it's cheap, and it cuts good, but it's really dusty. Too bad you were not closer! Good luck! Thanks for the kind words about my GTX! I appreciate it!
