Finally got some time, some substantial time to work on my car! One things for sure and certain, my work of 10+ yrs ago is not the same as today's! There's a LOT of examples of really bad and embarrassing work I did on this car and left as is for a number of years. Let me try to illustrate a 'cause and effect' of my doing, and solutions.
After hanging the qtr panels, the drivers side was just a wee bit too high, this was caused by my replacing the entire section including wheelhouses with a donor piece, this was back in 1999! Today, in undoing this mess, part of this is widening the wheelhouses to the Frame rails. I sectioned out the entire section, dropped it on the floor, then, the 2 piece el-cheapo trunk pan I installed back in 2004, I actually can't believe I didn't plug weld the pan to the Frame Rails! I just layed turd welds down on the Frame to Pan junction! Well, off it came, cut those welds, and ripped the Trunk pan out (well, still ripping it out). And, in the interest of full disclosure, I bought into some idiot's telling people on auto restorer . com to fill the frame rails with expandable foam! Well, yes, I did this, and, I can say that it's absolutely 100% gone now, and I don't read that site, nor do I take 'advice' from too many people on the internet, but, I will always share my folly and mistakes, and successes with you all here in the hopes that mistakes like mine won't be made by ya'll on your cars!
Widening the wheelhouses is actually pretty easy, just have some new inner wheelhouses on deck, cut about 2 3/4" from wheelhouse meeting point of Inner and Outer wheelhouses on the inside section, then use the new wheelhouse and screw it to the frame rail, and then cut the new inner to match the cut on the old inner, then butt weld them together.
I'll have most of this week available to tend to this, hopefully I can source a full AMD trunk pan this week from someone in town, get both wheelhouses done, widened, and new Trunk pan put in, properly and with no foam! Yeah, I only admit to the boneheadedness because I would hope that it may help others. Pics coming...
