Funship32
Hi all. Have a seemingly stupid question for you out there. Have a '69 RR which I took the side glass (driver side door) out of and had to remove the old rivet in the process. Not a problem since I purchased new glass rivets from Yearone. However I'm trying to figure out how to punch the center push pin in on these new rivets. I get the concept of installation...install rivet, push pin in which locks the tangs into place and voila'- the window lift bracket is secured to the window. However on these new rivets, it seems as though the "pins" are one molded to the rivet housing. I tried to gently push it in with no luck. Tried to push it out with the same result- no luck.
Was wondering if any of you have worked with these new aftermarket rivets and what you did to get the pin pushed in. Thanks in advance.
![BangHead :BangHead: :BangHead:](/moparforum/styles/default/xenforo/smilies/BangHead.gif)
