ramairthree
I am replacing my old beat 14inch mopar rally wheels with new 15 inch reproductions.
This is for a 74 Roadrunner.
on the front will go 15x7s with 4.25 inch backspacing,
and depending on what rear tires i use will go with 215/70s or 225/70s.
I have found posts that show215/70 will fit just fine in front. Do the 225/70/15s fit fine in front to? I thought I read a post where they did but cannot fint it.
On the rear, if I go with 15x7 all the way around, I will used 255/60s. (and the 215s up front)
If 275s fit fine on a stock 74 RR, I will go with 15x8s.
I have found posts that say the 275s are fine, and post that says it is too big.
Anyone here running 275/60/15s on their 74 RR and how do they fit?
Also, what size backspacing did you go with if they do.
Thank you.
Thank you.
