Drag car shocks?
What are your rear shocks set at and what time are you running? Bottom hole? I’m going to the track tomorrow with new Vikings all the way around and am guessing on a base setting.. going 13 compression 3 rebound front and rear to start
I was 12 c 6 r for the rear and it worked fine with the n/a tune. Still haven't gotten any good passes with the Vikings as Summer has been crazy at work. Yes, bars in the bottom hole.
I can say 14 compression and 3 rebound did not work bars were in top hole..spun instantly.. front torsion bars full loose car moved up about two inches front and rear then broke loose.. tried different settings same thing went home I’ll try bottom hole next time
