98 SNAKE EATER
My '69 RR has a Team G intake and a Demon Dominator carb.
Hood clearance is a bit of a problem, so it's been running without an air cleaner since it was built :icon_redface:
After some quick measurements, I figured I could ditch the 1" carb spacer to make some room for a custom air cleaner :cool:
Pulled the carb to rebuild over the weekend and realized the spacer had the only vacuum port
So now the plan is to drill and tap the intake for a vacuum port, but after eyeballing the intake, the front and rear walls look to be much thicker than the sidewalls....
They're also curved whereas the sides are flat.
I've always seen ports tapped into the front or rear of race intakes, but would I have any issue tapping into the sidewall?
I figure vacuum is vacuum, right?
