BeepBeepRR
I was changing the 3.91 gears to a 3.23 and decided to change the ujoints while I had it apart.
Went to the local napa and could not get the right u-joints. So I have to ask you guys if you know or recognize what this drive shaft may have come out of. I'm pretty sure its from an older model car.
Spicer driveshaft I can get the numbers off of it.
Spicer 621 on one of the old u-joints
Spicer 269 I think on the other. One is inner clipped into place and the other has the outer clips to hold it in. I believe thats on the front u-joint
