- 8:14 PM
- Apr 13, 2012
- Granite Bay CA
This was exactly my thought. You're simply changing the angle, the section of the linkage forward of the carburetor stud gets tilted down for clearance. The result is fore-aft movement on a more level plane. The whole assembly behind the carburetor stud will sit closer to the air cleaner but may not touch at all.So from the red line to the yellow line. Looks like a nice bend that you can work with.
I have a bunch of various linkage pieces that I've pulled over the years. I've bent, cut, welded and modified many for a variety of uses.
Send me a PM if you want a few sections. I'll send them for the cost of shipping. You can make something fit and hide under the air cleaner if you have a grinder and a welder.
