IQ52; while you are correct, I took it from the point of view of bang for the buck. By all means, if someone wants to spend *** for there aluminum heads on a stock engine, why go right a head and feel the power difference blow you draws right off your legs.
I still stand by what I said because I really do not feel it is not worth the money to put aluminum heads on a stock engine with a small or stock cam. It isn't going to be the big power maker worth jack when all is said and done.
Sorry to all for any misunderstanding in what I wrote to what I ment to say and the feeling of the post I made must have been poor.
I still see the iron head as worthy area to put bucks into if the goal can be me cheaply enough.
I absolutely agree with your iron head observation. Here are some flow tests with the 452 iron head compared to an OOTB Edelbrock VICTOR. 1) stock 452, 2) 452 with 2.14/1.81 valves, 3) test #2 with minor throat and bowl work, 4) #2 & #3 with porting, 5) OOTB Victor
Lift............(1)...........(2)...........(3)...........(4)............(5)
.100.......61/55.......64/56.......67/60.......68/60........68/63
.200.....130/108...133/114....137/130...142/130.....133/124
.300.....188/152...187/149....199/187...205/187.....201/179
.400.....213/172...211/166....239/218...248/218.....250/218
.500.....227/178...224/170....256/234...286/234.....287/240
.600.....230/181...229/171....262/245...292/245.....307/253
Note that just installing big valves in the 452 head actually hurt the flow until the supporting throat and bowl work was done. There was no additional porting done to the 452 exhaust after the initial clean up because even after some serious intake porting, the exhaust was flowing 84% of the intake.
Look what the ported 452 head can do compared to the OOTB Victor up to .500" lift. The valves, guides, seals and porting for the 452 will cost less than the Victor heads purchased with the valves and seals.
The real trick is finding the line where rebuilding or buying new is best.
