Background:
I have been tuning the induction on a factory spec rebuilt 1964 413 Max Wedge and wanted to pick the brains of those familiar with the Carter AFB and particularly cross-ram AFB setups. The engine is backed by a TorqueFlite 727 with a custom PTC torque converter with 3,500 RPM flash stall. The intake is a factory cross ram 24027261 with two 1965 3871S carburetors off a 413 that I rebuilt to factory specs. These AFBs don't have secondary velocity valves or secondary auxiliary air valves like the AVS. Aside from the secondary venturi clusters, there's nothing in the venturis from the air cleaner to the throttle plates. The secondary linkage is set to factory spec. I have the primary and secondary circuits dialed in to where the engine runs very well under almost all street driving conditions except for a bog/stall issue I'll explain after the background info. The fuel supply is steady with 3/8" diameter line and fittings running from the custom tank pickup through the pump and filter into a distribution block that takes 5/16" lines to each carburetor. I have confirmed that the high-flow pump at a regulated 3 psi are keeping the bowls full and that float level is properly set. The bowls are full when the stall/bog occurs, so fuel supply at the bowls isn't a culprit.
After playing with jets, rods, and springs, the engine runs best with 5 inHG orange springs and the following air-fuel ratios:
Idle: 14:1 - 15:1
Light throttle and Cruising: 11:8 - 13.5:1
WOT: 12.5:1
I experimented with leaning out the light throttle and cruising AFR with the next leanest rod but got two 14.5:1 lean surge spots between 2,300 - 3,000 RPM that I could not tune out until richening to the above range. I tried going down one and then two primary jet sizes but got similar lean surge spots. With the current rods and jets producing the above AFR, I fine tuned the light-throttle AFR via the idle mixture screws to where I get the best overall running condition under light load with the screws 1-1/2 turns out. 1-3/8 turns out leans out the light throttle by about .3, but the engine runs better at the richer 1-1/2 turns out. I'm using factory volume accelerator pumps with the rods set in the middle hole. If I speed up the shots by setting the rods in the first hole from the fulcrum, I get a little popping off idle under load. The carburetors have the factory accelerator pump discharge nozzles.
The ignition system is a rebuild 1974 factory electronic distributor, new matching coil and ballast resistor, blue high-rev ECU, quality wires, and Autolite 85s. I dialed in timing to the following. Everything is working well.
11° initial at 850 RPM
34° with mechanical all in by 2,200 RPM (23° from mechanical)
56° total with vacuum advance (it has a factory 22° vacuum canister)
Issue:
With the background covered, now to the issue I'm struggling to root out. The throttle response under load is excellent from idle through 6,000 RPM shift point except for the following conditions:
-When driving and mashing the throttle wide open at any point under 4,000 RPM, the engine essentially dies and can be heard pumping air. If I let off the throttle, the engine comes back immediately. If I keep my foot at WOT, the engine pumps air for about 2 seconds before picking back up and is a rocket from there on. The AFR gauge goes all over the place during the stall/bog and isn't any help diagnosing but equalizes at 12.5:1 when the engine picks back up.
-If I'm rolling in 1st or 2nd gear above 4,000 RPM and mash the throttle wide open, I don't get the same stall. At 4,000 RPM, the engine bogs slightly but quickly picks up. At 4,500 RPM and above, I get no bog but steady power.
-If I gently roll into WOT, I get smooth acceleration and no bog/stall.
-Once in WOT past the point of stall/bog, the engine runs great and doesn't starve for fuel.
I have experimented with all the metering rod springs including the 8 inHG to bring in the power step sooner and have sped up and slowed down the accelerator pumps via the linkage holes with absolutely no change in the bog/stall suggesting it's not a fuel shot issue. I don't smell raw fuel during the bog/stall, so I doubt the accelerator pumps are flooding the engine. Mechanical timing is all in by 2,200 RPM suggesting it's not a timing issue since the bog/stall still happens above that RPM.
Here's my thinking: The quick WOT bog/stall is due to a abrupt drop in velocity due to the eight throttle plates opening and the lack of secondary air valves used in the Carter AVS. When the primary and secondary throttle plates quickly open, the velocity falls off hard for a couple seconds until it builds enough where the engine picks back up. I don't get the bog/stall issue when the engine is far up in the RPM range or when rolling into WOT because there is enough velocity to overcome the increase in air volume. I have heard of people experiencing the engine falling off on hard acceleration with the AFB, but I have never had that issue with a single AFB on a low-rise intake manifold. This is the first time I've played with dual AFBs or cross-ram though, and the additional velocity needed for the ram and the additional volume from the second carburetor might be bringing the issue to light. The good thing is that normal street driving won't produce the issue since it's not common to need to mash to WOT at lower RPM. The one place on the street that it's an issue is for transmission kickdown if I'm cruising down the highway at 3,000 RPM in 3rd gear and need to hit the throttle quickly to actuate the kickdown. When I do so, the engine stalls for a second or two, the transmission drops into 2nd, and then the engine picks back up. That's obviously not an ideal situation. The car will see 1/4-mile track time where the issue will harm performance and predictability since even if brake standing at 4,000 RPM (if I can even predictably hold the car from moving) there is still a slight bog when going WOT off the line to where I will need to learn to roll into it at the same timing just enough to stop the bog.
Can anyone with experience running dual AFBs and or/cross-ram induction confirm if this particular bog/stall issue is a normal design side effect? Did the 413 and 426 Max Wedge engines have this issue from the factory? Does anyone have advice on how to improve the bog/stall issue more than I already have? Because the car is a period build and uses the smaller-diameter AFB air cleaners, I don't want to move to Carter AVS or Edelbrock AVS carburetors if I can avoid it.
Thanks for the help.
