Dave27
New Member
I bought a 68 dodge charger 440 R/T and the previous owner installed the dual pickup line out the side of the pan to the pump and then a dual oil filter relocation to the other side of the engine mounted to the inside of the frame but never finished hooking up the lines. Sooo I had 2 steel braid lines made ran them hooked them up(none of my stuff leaked). I have read the dual pickup is a great add on but I dont know about the relocation of the filters is this a good setup or should I remove the relocation filters and steel braided lines and just install the single filter on the pump side.It all appears to be working but I have an oil leak at the pump it appears to be coming from one of the oil pump hold down bolts but I need to verify.Thoughts or any help much appreciated I am new to mopars.Thankyou.....Dave
