My cable operated 727 has developed a major transmission leak. Traced it to the throttle pressure (downshift) seal. Actually came out easily. The new NAPA seal installed albost too easily IMO. Just by hand while laying under the car. I did install the seal in the right direction with the smooth side toward the arm. I used a 7/16" thinwall deep socket to try pushing deeper into the case. Just by hand, no hammer. Small, thin 5/16" flat washer same OD as the seal, then I put the old seal on the shaft thinking that it would provide pressure to the new seal. A thin 5/16" nylon washer, then the arm as tightly pushing everything into the case as I couls by hand. While putting the downward pressure on the arm, I tightened it. I did not use the thick original washer as there was no room now.
Still leaks from the kickdown. Here's my question; because of the ease of the installation of the seal, is there an oversize seal available? Just didn't feel tight enough to me.
Thanks.
Thanks.
