saintly616
New Member
I am working on a friend's '78 Magnum.Looks stock with a 318.He removed alternator(replaced with 120 amp)and when installing he did not notice that positive wire (to batt)was touching(grounded) the side of alt.
After connecting the battery,some 30 seconds later the cable started to smoke and he disconnect it but too late to save the battery.
To make matters worse,he removed the ECU and harness and not sure of wiring.
PROBLEM:Engine starts normal,runs great for 10 seconds,then very rough,spark knocks(or so it sounds)then dies.If you rev to 2000 or so,will keep running very rough with lots of noise.
From harness (with sending unit leads) I have blue and brown which I believe are run and start wires.I tried switching and disconnecting one,then the other,and seem to function properly.....
QUESTION:Try a new voltage Regulator(heard it click during meltdown) or ECU.
I own a '68 Charger with single ballast and 4wire ECU,this one a double with 5 wire.
Thanks
Thanks
