FOR SALE Edelbrock 650cfm AVS2 for sale - small repair needed, big price reduction
TopBanana72
12:57 AM
Ohio
Greetings, I have a newer, hardly used (maybe 100 miles) 650cfm Edelbrock AVS2 carb. I used it for a bit and went to adjust the idle mixture screws. I got careless and the passenger side tip broke off in the body as you can see in the photos. It was my mistake for sure, but if you can dig out the broken bit and replace the screw you should be good to go. I ended up buying another one and was more careful. So... I thought I would offer this one to friends here on FBBO for a greatly reduced price from new of $225.00 plus shipping (or you can pick up at Carlisle). You will need to supply the new idle mixture screw (which Edelbrock sells) and also add the large vacuum port plug (which I used on the other one). BTW.. these carbs are fantastic. The other one is the bomb on the Charger.
