Geoff 2
I also wondered about the jetting 'strategy' of the E carbs. There is also the very low fuel level in the bowl resulting from the 7/16" setting. I have seen a few Carter AFB/AVS carbs with a 3/8" float level setting, never 7/16", more common is the 7/32 - 5/16" range.
The low fuel level might explain the big jump between the cruise step & the power step on the met rods. Doesn't explain the relatively smaller sec jets, also being fed from the same low fuel level. Edel may have changed the main air bleed sizes as a way of changing the fuel curve.
