moparjohnny
Carb worked good for several days,maybe fuel pump is bad. I have a glass filter and no gas is in it after i pump carb.
When did you put the 5 gallons in it?Carb worked good for several days,maybe fuel pump is bad. I have a glass filter and no gas is in it after i pump carb.
do size change for the rod if i am using a regular material camshaft like a comp solid lifter. thanksWhen did you put the 5 gallons in it?If it's a big block we're working with, also check the length of the pump push rod inside the block. IIRC, it's supposed to be 3 1/4" long. You are also supposed to change it if you're using a billet cam. Many overlook this rod on a rebuild. They do wear out.
I'm getting old and crusty too, but I can still supply a little gas from time to time. Lol.i bought a full 3/8 fuel line with just rubber supply line needed at front and back,instead of the old 5/16 line with 3 or 4 rubber inserts and they are old and crusty.i will be buying a new gas tank and sender unit as well. i will be replacing all of this at the same time in april.
