LR1970
Hi everyone,
I am trying to figure out which Edelbrock head to choose. My car is a 72 Roadrunner with 440, 727 and 3.9 rear gears. I am using the revised purple shaft 509 cam, Edelbrock RPM inlet, Holley performance 750 vac carb and with headers and 3in exhaust. I know there are better cams out there but this is the one I have to use at the moment. I will be using pump fuel with 98 octane here is Australia.
I have calculated my compression as follows.
88cc = 9.84
84cc = 10.19
84cc = 10.39
75cc = 11.11
I'm thinking the 84cc will probably be the way to go. I'm wanting to bolt them straight on without any machining to the heads and inlet manifold.
Thanks in adavance
Leigh
88cc = 9.84
84cc = 10.19
84cc = 10.39
75cc = 11.11
Thanks in adavance
Leigh
