Edelbrock STR14-6 installation or...
joerg
4:46 PM
Austria
...how complicated a simple intake change can get. :toothy9:
I bought a nice Edelbrock STR14-6 Crossram intake a while ago and since the season is over here and the weather sucks now i took the old intake off the engine today with the intention to install this:
The overall height including, the aircleaner assembly, with the Edelbrock Six Pack intake is 28cm. The complete assembly with the STR14-6 is 33,5cm. Sure doesn´t fit under the OEM hood. :mad:
That´s why i testfitted this:
I still have the old hood that came with the car when i bought it, so i don´t need to cut the nice one. Will pick it up tomorrow at my parents house and see how it will work out.
At least i managed to testfit the base without any problems today :icon_cool:
I had a STR 14-6 intake on a 440 in my old 69 RR many years ago now it fit under the stock 69 N96 hood, I don't remember what air cleaner I used, it was in the 1980's, but the intake & carbs fit, that was a fun intake torquey as hell, noisy as hell when the secondaries open... easy to convert to a single 4bbl or dual 4bbl also, I tried them all at one point or another, there were some mods that had to be done, so the rear plugs didn't get fuel fouled all the time, it was a small 1/4" aluminum dam across the 2 rear ports in the box portion of the manifold, welded in place, to stop fuel from just draining down the back 2 ports under hard acceleration or at even just slow &/or constant cruising speeds, or some guys would even epoxy something in those areas instead... If I could have found a STR 15-6 {for less than a small Ransom}, for my Low Deck stroker build instead of the MP 6bbl low deck manifold, I would have used it, I have tons of hood clearance with the A-12 hood I have, on my current 68 RR project for sure, the cheapest one {STR 15-6} I could find was like $1500 for just the manifold & the one 6bbl top, so I passed on it & went with the MP 6bbl unit instead... That thing looks very cool, that's for damn sure, good luck, keep us posted...
I picked up my old hood during the weekend and started to work on it. There was lots of bondo on it and it got a lot lighter when everything was removed.
I also discovered that my 6 pack aircleaner isn´t sitting centered in my engine bay. For some here a well known fact but new to me. I decided to not just cut the aircleaners space requirement out of the hood but all the metal in the section where the scoop will be mounted at.
Looks good, keep us posted...
Another problem is the top lid. The carbs a mountend on an angle, which is compensating for the angle the engine is sitting in it´s bay.
I would have to modify my aircleaner base to make it fit. But since the linkage of the carbs won´t have enough space to move anyways i prefer to just modify the intake lid it´self with a milling machine and get rid of the carburators mounting angles and also cut a channel into the stiffening piece.
If I remember correctly, I used 1/4" or 1/2" heat insulator type thick Holley gaskets, under the carbs & had enough clearances for the carb linkages, I don't remember what air cleaner I used, it was a long time ago... There is a company F&B Throttle Bodies @ www.fbthrottlebodies.com , that makes a set of spacer/adapters to fit on top of their EFI 6bbl set up, to use a stock type air cleaner, that may help with the air cleaner base, you could mill them instead of modifying the air cleaner base... Possibly Promax carb company @ www.promaxcarb.com , also may have something, I think...
Today i took care of the angle the carbs were mounted at first. The milling machine was quite fun to work with.
I also installed the see thru plugs for the float bowls. Had them at home for half a year already and never felt like installing them. We also changed the main jets from 62´s to 64´s since the car was running a little lean when idling.
Then i took care for having enough space so the carb linkage can movve all the way it´s supposed to.
Last but not least i also ran into the problem that i couldn´t mount the fuel lines. But that was only a small
problem a grinder solved within 5 minutes
Then i put everything back together.
Looks good...
Today i drilled the holes for the accelerator cable and kick down linkage bracket
Then i mounted everything in the car and checked it for clearance and if everything was moving without resistance
Looks great, very clean & nice job...
Today i finished all the brackets for the ignition coil and everything and stumbled across a problem when i wanted to attach my brake booster hose to the vacuum fitting. The intake doesn´t have one.
Where would i drill the hole to mount the 3/8 vacuum hose fitting?
Take the top back off again, at the minimum, drill & tap one, oh no...LOL... I would say, at the back somewhere, on the base with a 90* nipple, pointing towards, the booster, would look the cleanest...
That's pretty sweet looking intake set up! Always liked the 6-pack.
Last time i worked on it, i drilled the hole for the brake boosters vacuum supply. Work is on hold at the moment since i´m in Germany until wednesday.
I´m also thinking of doing the modifications to the base budnicks mentioned earlier in this thread. Found drawings online so it shouldn´t be a problem i guess.
What does "retain this rib as cast" mean?
I would guess it means dont touch it, dont blend it, polish it......
That´s what i thougt too, but since my motherlanguage is german i sometimes have to use a translator and the translation i get doesn´t make sense at all.
Lots of progress here again! I did the necessary modifications to optimize flow characteristics.
I finished cutting up the old hood and attached the scoop to it.
Once the liqiud metal was hardened out i mounted the intake on the motor. I had a really hard time finding the 2 long screws inside the intake. At some point the SAE system is really anoying to work with over here.
Very nice, I stored a bunch of those photos, from your project, for future references, your doing a great job...
I also found another sheet from the very same book which gives you the jet size numbers etc...
