Anyone know if an Edelbrock 2475 intake w/6-pak carbs is the same height as stock mopar manifold/carb set-up? Trying to confirm it will clear underneath my ‘71 Charger R/T bubble hood (not a fresh air ramcharger)
Edelbrock 6bbl 2475 should be the same castings
as the 1969.5 Alum. version,
before Chrysler started casting them in Cast Iron
but it should work, should be the same height
I sure hope it fits. I have seen 1971 Charger R/Ts with the louver hood with 440-6.
I got a standard answer from Edelbrock - but cannot conclusively determine if anyone ever put a “stock” mopar cast iron or aluminum intake on a flat surface and measured same carb plane height dimension(s).
Edelbrock gave me: 5.25” carb plane height (5.63” tall in rear 4.875” tall in front divide by 2 for Carb plane at 5.25”).
Once I start the build I will get the answer out there for all to know.
