Al K
- 11:14 PM
- Nov 15, 2009
Gawd I HATE @#$%ing electrical issues.:angryfire: Throwing wrenches at the problem won't solve it.:sad3: It also can (bleep)-up the paint.
So;I've got the carb choke wired into the fuse box under the dash,where it's only on(supposedly) when the key is on. Well...it also seems to be a draw on the system. Going down the road,I see about 11.0 to 11.5 volts as indicated on the gauge. If I disconnect it at the carb while it's running,the voltage jumps to about 12.0-12.5 volts. Seems like it should be closer to 13.5+ when disconnected. Got a basic 75 amp alternator;should I upgrade to a 100 amp unit to counter the draw? Or,is there something else that's causing this issue? It sucks to drive around and constantly worry about a potential dead battery. It also means that driving at night(with or without the choke hooked up) is out of the question. Any suggestions,folks? I'll get some pics of the voltage regulator and where I've got the choke wire hooked up in a bit. I'm heading back out to the hot-*** garage(it's already 85+ degrees at 11 AM) right now and am probably going to rip all the tape off my wires and see if I've got a broken wire or some other crap causing the low-voltage issue.
As always,thanks!!!
As always,thanks!!!
