cuda71gtx2
Ok Guys Here is my Nightmare, I have a 70 Coronet, Turn the Key Nothing, Sometimes it will click 1 time, sounds like the Turn signal Flasher,I have lights,Emergency Flashers work, Turn Signals Work, But Nothing else works, I installed a Reconditioned Under Dash Harness, But still nothing, I checked Ignition Switch, with a Test light and it lights up, the wires are warm from the switch to the dash harness, I have put a New Neutral safety switch on, Still getting Nothing when i turn the key, Does anyone know how many grounds these cars are supposed to have, I have the Harness grounded to the dash Frame, But have not hooked up the Dash frame to steering Column Ground yet, I am At my Wits end, also i can crank the car at the starter Relay, Jumping the terminals, But it will not fire, Checked for spark, Pulled number one plug and cranked it over no spark, checked point gap and it is right has new coil, Ballast resistor,cap and rotor, I am stumped Beating my head against the wall, This is my first B Body, any and all help will be greatly appreciated, Thank You Terry
