- 6:56 AM
- Jan 29, 2018
- Midland Ontario, Canada
Sorry.. nadda on a switch in my spares!
Yes, the vacuum system makes a difference, but as far I recall is attached to the switch being not an integral part of the switch? Being posible to separate it. I can be wrong thought.The actual "chrome" rocker IS different between two and three speed - I know this for a fact.
I think the 3-speed switch is the same for all b-bodies 68-70. I know one switch IS different and I think its the headlight switch - which, on Chargers has a part to activate the headlight doors.
The only difference is that the neck on the 3sp switch is about.020 wider, so the 3sp knob mounting surface is .020 wider also. The knobs from the headlight and 2sp wiper switches are a very tight fit on a 3sp switch. They usually need a touch of filing.I can’t see any difference between 2 and 3 speeds rockers
Yes the arm is different. I could never find one when I converted my 68, so it went on without wipers, but the $300 3 speed wiper motor looked cool under the hood. You will need a 3 speed switch as well. Those seem easier to find.Isnt the linkage different or a piece of it?
