biginch=bigfun
I am having trouble nailing down an electrical issue : my voltage varies greatly! It bounces between 12v & 16v. If you drive at night the headlights look like stobe lights.
What I have:
1969 RR w/ a 440,
newer style alternator, 2 field
solid state regulator & ballast resister
MSD 6AL ignition
Amp gauge by passed, volt gauge installed
relays on low & high beam heaqdlights
What I have tried:
rewiring
putting my regulator on another car- worked fine
running my Batt. wire off the Alt. to the starter relay with a wire from the positive battery post to the starter relay.
Msd is powered at the positve post of battery.
Any help would be great! Thanks
LJB
What I have:
1969 RR w/ a 440,
MSD 6AL ignition
What I have tried:
rewiring
LJB
