robertheath
When I close the doors the dome light dims and the accessory light on the underside of the dash comes on. This happens when the car is off or on. In addition, the temp and fuel gauges aren't working. Both gauges are on the left side of the gauge cluster. The speedo and the gauges on the right side of the cluster both work fine. I'm not sure if these two issues are related but any help would be greatly appreciated.
The gauge cluster has two circuit boards, one for the left, and one for the right. I've tried multiple circuit boards on the left side and that doesn't seem to be the issue. Does the left circuit board need a separate ground? The right circuit board is grounded through the main wiring harness.
