Well the pink wire does indeed turn on the screen and power the ECU so thats one bit I figured out this morning.
Potentially could run it this way. I think I found a super simple solution though.Could we just run the pink wire to the battery as well with a switch to it to toggle on before/when you also turn the ignition key on? It would double as a kill switch for the car. I would think the amperage draw would be small on that circuit as it is just the trigger wire for the Holley ECU correct? Heavy duty toggle switch under the dash going from the battery through the switch to the unit with a fuse inline and done. Correct me if I am wrong.
