392hemix
I have a freshly built 1968 440 hp2 engine. it has original 906 heads and stock rotating assy. its got a solid lifter mopar 528 lift cam, and a single plane weind single plane intake. I am running a 850 qucik fuel carb, w/no choke horn, and its got a 8qrt pan with a windage tray, i also have the indy cast valve covers. My first problem is this one, #6&8 plugs are comin up very oily, and i have a single pcv valve and breather, but the tube is getting a little oil in it and i think that its giving me a rich conditon. What set up do you guys run for crank case ventalation or evacuation with these indy valve covers?....
