Definitely need mitigation, and I'm not able to check the engine for you - I would believe that there is another issue you should run tests to find - glad it seems OK, too much pressure ! Oil seals leaking coming next , pull the plugs and do a compression test @ a minimum - possible head gasket damage near oil feed ? Hope the best for you ✌
