Imndeep
Hi all, the header says it all. I've been living with this for awhile now and am frustrated as to what direction to go. After seeing this post I'm even more confused. http://www.forbbodiesonly.com/mopar...last-resistor&highlight=positive+coil+voltage
What is happening is that My '68 RR 383 stick, she'll fire right up, run til it get warmed up and or hot then just quit. Ya can't start it right away or you'll drain the battery. Wait 15 to twenty minutes and it fires right up. I'm, trying to determine if it's Coil or Carb or ignition no that I read that post. I am trying to figure out what the voltage to the positive side of the coil is suppose to be. I'm getting 3.9 to 4.2 volts and my meter flashes on and off again like a strobe for the first 20 seconds of reading. I just replaced my alternator because the bearings were shot and it was just old.
I am running a factory electronic distributor with a Mopar Performance Ignition Box which I assume is a MSD unit in disguise. Now from that other feed it says I don't need a ballast resistor going to my coil with a MSD box. I have a ballast resistor hooked up hooked up. So I think it's my coil heating up then quitting because if it was Vapor lock the engine would sputter before shutting off. There is no sputter. I'm posting some picts for you guru to disseminate. Let me know one way or another if I'm messed up or not? TIA
![](/moparforum/proxy.php?image=http%3A%2F%2Fi90.photobucket.com%2Falbums%2Fk273%2F144543%2F20150711_135917_zpsio5zfpzi.jpg&hash=89e4146e3158d12a513c4cfd959b797f)
![](/moparforum/proxy.php?image=http%3A%2F%2Fi90.photobucket.com%2Falbums%2Fk273%2F144543%2F20150711_135946%2520-%2520Copy_zps7tglmrbx.jpg&hash=d61f3f669c687e48862fe11a7df0e06c)
![](/moparforum/proxy.php?image=http%3A%2F%2Fi90.photobucket.com%2Falbums%2Fk273%2F144543%2F20150711_140013_zpsd1tm2gj7.jpg&hash=ae205496f841588a9dcb5fdbd3b20f92)
![](/moparforum/proxy.php?image=http%3A%2F%2Fi90.photobucket.com%2Falbums%2Fk273%2F144543%2F20150711_135955_zps0tpwnvgh.jpg&hash=e9c286f4f8896727f51836dafa723144)
