1 Wild R/T
My 67 Dart had 5.7 volts with Ign ON. The 75 Power Wagon had 6.4. Both start and run fine with no choke in 60 degree weather and above.
Slide a hotter cam in & tell me how they do...
I looked back at my notebook that I keep for the car. This started in June. The gas in the tank was full in February but it may have been filled up the month before that. My other cars can sit for longer periods and start up fine. Maybe having lower compression and milder cams allows them to run on crappy gas without too much trouble ?I would start with the basics and do a compression and leak down test, just to eliminate anything mechanical. You said it ran fine with no choke when cold and then out of the blue it runs like crap until warm? Id look into something more mechanical that is masked with a warm engine like a low cylinder etc. You seem to have most of the common crap dialed like vacuum leaks, ignition timing, voltages and crappy cali fuel. I will agree with WILD RT that this new fuel is garbage. We have over 50 cars that sit around so I do feel that pain.
Most of the efi set ups have diagnostic tools. The best thing is that they constantly change the tune based on optimum AF ratios. You can go from sea level into the mountains and never worry about it again!Oh, I have the budget but I figure that if I can't figure out a carburetor setup, I'd be far worse when an EFI problem pops up!
I did. It was just rebuilt.If closing the choke plate and covering the throat with you hand has not effect, then I believe you have a primary circuit restriction in the carb.
I'm surprised it runs OK when warm.
You need to clean it or put a clean carb on it.
Keep us posted.
